Topics covered in this article:
π New to Wyze and Rules? Start here:Using Rules in the Wyze app
What are Preset Rules?
Preset Rules are some of our most-popular Rules, already set up in the Wyze app for you to use with just a few taps. Instead of manually creating a rule, select a Preset Rule and customize it before tapping Save.
Some Preset Rules are:
Type of Rule | How it works | Requires | |
Turn on lights when a person is detected | Device trigger | If a camera detects a person, the lights turn on. | Wyze camera, lighting and a plug, and Cam Plus / Protect subscription |
I'm home | Shortcut | Tap this shortcut to turn off your cameras when home. | Any Wyze camera |
Turn lights off when I'm away | Location trigger | When you leave an area, the lights turn off. | Wyze lighting or plugs, location enabled |
Turn alerts off at night | Schedule | App notifications turn off from sunset to sunrise. | Any Wyze device |
π€« There are hidden Preset Rules that display based on the Wyze devices you have. Get a new Wyze device? Keep an eye π out for new Preset Rules to try out!
Where do I find Preset Rules?
Find Preset rules on the Create Rule screen (Home > + plus sign > Add Rule).
How do I use Preset Rules?
- On the Home screen of the Wyze app, tap on the + plus sign.
- Tap Add Rule. Find your list of Preset rules on the next screen.
- Tap an option under Preset rules.
- Review and make changes the list of devices/actions if needed.
- Tap Save.
How do I edit or delete a Preset rule?
- On the Home screen of the Wyze app, tap the pencil (Edit) icon.
- Tap Edit Rules.
- Tap on the Preset rule you want to edit/delete.
- To edit a rule, make changes directly on this screen.
- Rename the rule, or add and remove actions here.
- To delete the rule, tap Delete Rule and confirm.
