How do I turn on Color Night Viewing?
To turn on Color Night Viewing:
Wyze Cam Pan v3 is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night. It works best to use this feature in low light settings, by turning Night Vision off.
  1. In the Wyze app, tap on your Wyze Cam Pan v3.
  2. Tap on the Settings gear, then Advanced Settings.
  3. Below Night Vision Mode, tap Off
Still need help?
