Can I use Rules with Wyze Home Monitoring?
Yes, you can use Rules to automate your home monitoring system. This will specifically allow you to automate the arming and disarming of your system.
Before setting up new Rules, make sure your Wyze Home Monitoring subscription is active.
To set up Rules with Wyze Home Monitoring:
  1. In the Wyze app, tap on the Monitoring tab.
  2. Tap Home Monitoring Settings > Home Monitoring Rules.
  3. Tap Create Monitoring Schedule.
  4. Select the Mode (Disarmed, Home or Away).
    1. Select the time that you want that mode to be triggered.
      • Tap Save to save your changes.
    2. Select the days you want the rule to be active on.
  5. Tap Save.
Still need help?
