Can I connect via the dongle and Bluetooth at the same time?
Yes, but you can only receive audio from one source.
While you can be connected to a device via Bluetooth while also having the dongle connected, you can't listen to audio from both simultaneously. Use the Multi-Function Button to switch between the two.
Still need help?
