My Wyze Cam Floodlight is not following the set schedules.
Problem
My Wyze Cam Floodlight is not adhering to the schedules that I set.
Troubleshooting
  2. Check that both your Wyze Cam v3 and Wyze Cam Floodlight’s firmware are up to date.
    2. If there is an update available for the devices, please move forward with updating them.
  3. Check your Wyze Cam Floodlight’s settings to ensure they are accurate.
    1. In the Wyze app, navigate to your floodlight’s settings.
    2. Under Floodlight Control, select Auto.
    3. Under Turn on when dark, select Always.
  4. Check to see if there are any Rules set for the camera or floodlight that may be conflicting with the settings.
    1. From the Home tab of the Wyze app, tap the pencil icon in the upper right.
    2. Select Edit Rules
    3. Edit or delete any rules that may be conflicting with the floodlight or its associated camera(s).
  5. Power cycle the floodlight and camera.
    1. Start by flipping the breaker to the off position.
    2. Wait 5-10 seconds, and then turn the breaker back to the on position.
  6. Delete your Wyze Cam Floodlight from the Wyze app.
    1. In the Home tab of the Wyze app, tap the pencil icon in the upper right corner.
    2. Tap Edit Devices.
    3. Tap the red removal icon next to the floodlight then tap Delete
  7. Factory reset your Wyze Cam v3.
    1. Remove any microSD card inserted into the camera.
    2. With the camera plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera and floodlight as new.
  8. Recreate the Rules one by one and test if they function as expected.
Still need help?
