My Wyze Cam Floodlight is interfering with my garage door controller.
Problem
Your Wyze Cam Floodlight is causing interference with your garage door controller.
Troubleshooting
  2. Check that both your Wyze Cam v3 and Wyze Cam Floodlight’s firmware are up to date.
    2. If there is an update available for the devices, please move forward with updating them.
  3. Power cycle the floodlight and camera.
    1. Start by flipping the breaker to the off position.
    2. Wait 5-10 seconds, and then turn the breaker back to the on position.
  4. Delete your Wyze Cam Floodlight from the Wyze app.
    1. In the Home tab of the Wyze app, tap the pencil icon in the upper right corner.
    2. Tap Edit Devices.
    3. Tap the red removal icon next to the floodlight then tap Delete
  5. Factory reset your Wyze Cam v3.
    1. Remove any microSD card inserted into the camera.
    2. With the camera plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera and floodlight as new.
Still need help?
