Get the most out of your Wyze app using these helpful tips!
At the top of the Home tab of the Wyze app, you will automatically receive helpful tips to give you the best Wyze experience. These pop-ups cover a wide array of topics such as Two-Factor Authentication, how to utilize Rules, how to share your devices, and more!
To remove the current discover cards, simply swipe them away!
To adjust the frequency or disable your discover cards:
- In the Wyze app, tap the Account tab.
- Tap Notifications > App Discovery.
- Under Discover Tips, tap Frequency.
- Select the desired frequency. You can choose between
- Never
- Note: This option is only available on Wyze app version 2.40 or newer.
- Every 3 days
- Every week
- Every month
- Never
- Tap Save.
