Skip to main content
How do I remove my Wyze Video Doorbell Pro?
Danielle
Wireless Installations
- Using the included screwdriver, unscrew the security screw located at the bottom of the doorbell.
- Slide the doorbell up and away from the wall, disengaging the locking mechanics on the back of the doorbell.
Wired Installations
- From your electrical panel, power off the current leading to the doorbell.
- Release the extension wires.
- Take off the wire caps and unscrew/untwist the wires from your house to the doorbell, separating the two.
Have more questions?
Submit a request
