The LAN side of your Wyze Mesh Router by default will issue dynamic addresses in this private IP address range: 192.168.50.xxx.
Most users will never need to change these settings, but if you're upgrading from an older system and want to keep the same set of IP addresses and reservations by creating a custom DHCP range, follow these steps:
- In the Wyze app, select your Wyze Mesh Router.
- Tap the gear icon in the upper right-hand corner.
- Select Advanced Settings.
- Select IP Address.
- Tap LAN IP.
- Choose Manual DHCP IP and choose the starting IP, ending IP, and subnet mask you'd like to configure.
