Introducing Wyze Cam Floodlight Pro
See it all in frame with the widest view in the game!
Features we love about Wyze Cam Floodlight Pro:
  • 180° Ultra-Wide Camera View - A pro floodlight category-leading 180° field-of-view means you can see more and protect your property from end-to-end.
  • 2.5K QHD Resolution - Capture images and video with greater detail with stunning Quad High Definition clarity.
  • AI-Powered Light Control - Goodbye, clumsy PIR technology. Wyze Cam Floodlight Pro uses onboard AI computer vision to detect long-distance motion with more accuracy. Plus, it only triggers the lights for objects you select, like people and vehicles, and sends notifications to your phone.
  • 3000-Lumen Tri-Head LEDs - Adjustable and dimmable LEDs provide evenly dispersed light that won’t wash out images. Three independently articulating panels let you customize light coverage to meet your needs.
  • Introducing Ambient Light Mode - When enabled, the floodlight provides constant ambient light until motion is detected and automatically switches to increased brightness.
  • Motion-Activated Voice Deterrence + Loud Siren - From in-laws to outlaws, the “Hi, you are currently being recorded” voice prompt and built-in 105 dB siren are sure to deter all kinds of unwanted visitors.
  • Color Night Vision + Powerful IR Night Vision - Our award-winning starlight sensor amplifies low light for vivid color images. Extra dark out? Flip on traditional night vision for crystal-clear images in even the darkest of nights.
  • Dusk-to-Dawn Automation - Wyze Cam Floodlight Pro knows when the sun goes down and when it comes up. No need to manually turn it on or off once it’s connected.
  • 24/7 Video Recording with a MicroSD Card* - Don’t miss a thing with continuous local recording to microSD cards up to 256GB.
  • Dual-Band Wi-Fi - Connects to either your 2.4 GHz or 5 GHz network.
  • Instant BluetoothⓇ Setup - No more QR code scanning. Setup is quick and easy with BluetoothⓇ.
*MicroSD card sold separately.
Still need help?
