What is the Siren and how does it work?
It is a really loud, 105 dB speaker.
Wyze Cam Floodlight Pro has a speaker inside that can be used as a siren to ward off intruders.
To control the Siren feature:
  1. In the Wyze app, tap on your Wyze Cam Floodlight Pro.
  2. Under the live stream, tap Siren. (Be careful, it’s loud!)
    • To turn it off, tap Siren again.
Can another device trigger the Siren?
Yes! You can do this via Rules (specifically Device & Service Triggers) in the Wyze app. You can learn more about using Rules with Wyze Cam Floodlight Pro here.
Note: With the 2.48 Wyze app version, you can set the floodlight to flash when the siren is triggered. To enable this in the Wyze app, you'll want to go to your Wyze Cam Floodlight Pro's settings > Floodlight Settings > enable/disable Flash Light with Siren.
Was this article helpful?
0 out of 0 found this helpful
