What is the Siren and how does it work?
It is a really loud, 105 dB speaker.
Wyze Cam Floodlight Pro has a speaker inside that can be used as a siren to ward off intruders.
To control the Siren feature:
  1. In the Wyze app, tap on your Wyze Cam Floodlight Pro.
  2. Under the live stream, tap Siren. (Be careful, it’s loud!)
    • To turn it off, tap Siren again.
Can another device trigger the Siren?
Yes! You can do this via Rules (specifically Device & Service Triggers) in the Wyze app. You can learn more about using Rules with Wyze Cam Floodlight Pro here.
Still need help?
