Why do I have to enable Location Permissions to use Wyze Cam Floodlight Pro?
It is needed for setup and lighting controls.
By default, motion-activated light triggers and our new Ambient Light feature are only enabled after sunset and disabled after sunrise. To accurately determine your local sunset and sunrise times, Location Permissions are required during the setup process. Of course, you can always customize your light’s start and end times for each feature in your Wyze Cam Floodlight Pro’s settings in the Wyze app once setup is completed.
Still need help?
