My Wyze Cam Floodlight Pro firmware fails to update.
Problem
When I try to update the firmware for my Wyze Cam Floodlight Pro, it fails.
Troubleshooting
  2. Ensure that Wyze Cam Floodlight Pro has a good signal strength.
    1. You can check this in the Wyze app by going to the floodlight’s settings > Device Info > Signal Strength.
    2. If it has less than 2 bars, try moving the router closer to the floodlight.
  3. Reboot the router.
  4. Power cycle Wyze Cam Floodlight Pro.
    1. Switch the breaker to the off position.
    2. Wait 5-10 seconds.
    3. Switch the breaker back to the on position.
  5. Factory reset Wyze Cam Floodlight Pro.
    1. Remove any microSD card inserted into the floodlight.
    2. With the floodlight powered on, press and hold the setup button on the back of the camera for 10 seconds until the status light on the bottom of the camera turns solid red.
    3. Once the status light starts flashing purple, set up the floodlight like new.
      • Try connecting to a 2.4 GHz Wi-Fi network when setting up the floodlight again.
Still need help?
