My floodlight is creating too many false alerts.
Problem
You’re receiving too many false detection alerts, notifications, and/or false light triggers due to motion from your Wyze Cam Floodlight Pro.
Troubleshooting
  2. Check that your Wyze Cam Floodlight Pro’s firmware is up to date.
    2. If there is an update available for the floodlight, please move forward with updating it.
  3. Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS, make sure that Precise Location is turned on.
  4. Ensure the floodlight is set to record correctly.
    1. In the Wyze app, navigate to the floodlight’s settings > Event Recording
    2. Enable Record Motion Events.
    3. Enable All Motion Events.
      • Note: If you don’t have Cam Plus enabled, there will automatically be a 5-minute cooldown period between thumbnails.
  5. Verify that the Detection Settings are set correctly.
    1. Navigate to the floodlight’s settings > Detection Settings.
    2. Under Motion Detection Sensitivity, adjust the slider bar to a lower value.
      • We recommend about 40 or lower.
    3. Tap Detection Zone and toggle it on.
      1. Create a detection zone to exclude areas where you don’t want to trigger the floodlight.
  6. Check that the Notifications are set correctly.
    1. For the floodlight:
      1. Navigate to the floodlight’s settings > Notifications.
      2. Enable Notification.
      3. Enable Person and Vehicle.
    2. For the Wyze app:
      1. Navigate to the Home tab of the Wyze app.
      2. Tap Account > Notifications > Push Notifications.
      3. Toggle on Push Notifications
  7. Verify that there are no Rules set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app, tap the pencil icon in the upper right-hand corner > Edit Rules.
    2. Note: We recommend deleting any Rules and then adding them back one by one while testing.
  8. Power cycle Wyze Cam Floodlight Pro.
    1. Switch the breaker to the off position.
    2. Wait 5-10 seconds.
    3. Switch the breaker back to the on position.
  9. Factory reset Wyze Cam Floodlight Pro.
    1. Remove any microSD card inserted into the floodlight.
    2. With the floodlight powered on, press and hold the setup button on the back of the camera for 10 seconds until the status light on the bottom of the camera turns solid red.
    3. Once the status light starts flashing purple, set up the floodlight like new.
Still need help?
