What is the Siren and how does it work?
It is a really loud, 80 dB speaker.
Wyze Battery Cam Pro has a speaker inside that can be used as a siren to ward off intruders.
To control the Siren feature:
  1. In the Wyze app, tap on your Wyze Battery Cam Pro.
  2. Under the live stream, tap Siren. (Be careful, it’s loud!)
    • To turn it off, tap Siren again.
Can another device trigger the Siren?
Yes! You can do this via Rules (specifically Device & Service Triggers) in the Wyze app. You can learn more about using Rules with Wyze Battery Cam Pro here.
Was this article helpful?
0 out of 0 found this helpful
