My Wyze Battery Cam Pro has poor audio quality.
Problem
You hear poor audio quality when speaking through your Wyze Battery Cam Pro or in recorded events.
Troubleshooting
  2. Check that your Wyze Battery Cam Pro’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure there is nothing impairing the camera’s microphone or speaker.
    • Remove any plastic film/cover on the microphone or speaker.
    • Gently blow on or wipe the microphone or speaker with a soft cloth to remove any dust or debris.
    • If there is a third-party cover on the device, please remove it.
  4. Verify that audio is enabled in the camera’s live stream.
    1. Navigate to the camera’s live stream.
    2. Tap the live stream then tap the speaker icon to toggle the sound off/on.
  5. Ensure Record Sound is enabled.
    1. Navigate to the camera’s settings > Advanced Settings.
    2. Toggle on Record Sound
    3. When viewing recordings, ensure the video sound is not muted.
  6. Ensure Wyze Battery Cam Pro has a good signal strength.
    1. You can check this in the Wyze app by going to the camera’s settings > Device Info > Signal Strength.
    2. If it has 2 bars or less, try moving the camera closer to the router.
  7. If you are experiencing poor audio when using the 2-way audio feature, adjust the live stream resolution to HD.
  8. Force close the Wyze app.
  9. Increase the volume on your phone/tablet.
  10. Test the audio on a different phone/tablet or try switching to mobile data, if possible.
  11. If you have a microSD card inserted into the camera, remove it and check if your recordings have the same audio issue.
  12. Power cycle Wyze Battery Cam Pro.
    1. Remove the battery pack completely for 10 seconds, then place it back into the camera, ensuring it is seated firmly.
  13. Factory reset Wyze Battery Cam Pro.
    1. Remove any microSD card inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light turns solid yellow.
      • To access the setup button, you will need to open the camera's battery compartment.
    3. Once the status light starts flashing yellow and blue, set up the camera like new.
Still experiencing issues? Please reach out to our support team with the following information and they’ll be happy to help!
  1. An app log.
    • You can find steps on how to submit an app log here.
  2. The MAC address of the camera.
    • You can find this by opening the battery compartment of your Wyze Battery Cam Pro or in the Wyze app by going to the camera's settings > Device Info.
  3. A picture, screen recording, and/or downloaded Event (if applicable) showing the issue.
  4. Details about when this issue first started.
Still need help?
