How to limit false alerts or detections.
Mount it in the best location and adjust the detection settings.
You’re already halfway there with Wyze Battery Cam Pro! Radar and PIR technology work together to provide precise detection so you can feel confident in every alert you receive.
The PIR sensor uses passive infrared technology to detect changes in temperature while radar technology detects the distance of objects in front of the camera to provide precise information about detected motion to reduce unwanted alerts.
Note: The camera lens, PIR sensor, and radar sensor must be oriented properly for features like Person Detection (Cam Plus required) and Motion Detection to work properly. For proper mounting, check out our Wyze Battery Cam Pro Mounting Guide.
For additional customization, you can adjust the detection settings all from the Wyze app!
To adjust the Detection Range:
  1. Navigate to the camera’s settings > Detection Settings.
  2. Under Detection Range, adjust the slider bar to your desired distance.
To adjust the sensitivity:
  2. Under Detection Sensitivity, adjust the slider bar to your desired sensitivity.
To set up a Detection Zone:
  1. In the Wyze app, pick the camera you would like to edit by selecting it to enter the live stream.
  2. Tap the Settings gear > Detection Settings Detection Zone
  3. Toggle Detection Zone On.
  4. With the Detection Zone on, draw on the grid to set your motion detection target area. The Detection Zone will be saved automatically.
Still need help?
