What are Tune Settings?
Tune Settings is a feature that plays a sound from your hub when an entry sensor is triggered.
To enable Tune Settings:
  1. In the Wyze app, navigate to the Monitoring tab.
  2. Tap Home Monitoring Settings > Tune Settings.
  3. Select the available sensor(s) you’d like to use then tap On.
  4. To adjust the sound volume, select your Wyze Sense Hub, then adjust the volume between Low, Mid, or High.
Note: This feature only works with Wyze Sense Entry Sensor v2 and requires an active subscription to Wyze Home Monitoring.
Still need help?
