Introducing Wyze Video Doorbell v2
Wyze Video Doorbell v2 gives 2K porch protection with local microSD storage.
Wyze Video Doorbell v2 works with your in-house mechanical chime and lets you answer your door from anywhere using the Wyze app.
Note: Wyze Video Doorbell v2 is a hardwired doorbell that connects to your existing wired and chime. Wyze Video Doorbell v2 is not wireless and is not battery-powered.
Wyze Video Doorbell v2 Features we're jazzed about:
  • 2K Video Resolution with Head-To-Toe Viewing. Capture all porch arrivals and departures in greater detail.
  • 24/7 Local Recording with a MicroSD Card. See what happened start to finish with continuous local recording. Get a MicroSD Card here.
  • Existing Doorbell Chime Support. No more bypassing your home's existing chime!
  • Free 12-Second Video Recordings. Get up to 14 days of cloud storage for clips captured on every doorbell press and when the microSD card is ejected.
  • Motion-Activated Video Deterrence. When enabled, a voice prompt plays to alert visitors that they are being recorded.
  • Pre-Roll Recording. As a wired doorbell, you get 3-6 seconds of pre-roll recording for motion events, so you'll never miss any of the action.
Still need help?
