How do I share my Wyze Cam?
Sharing is a feature that lets other people access and use your Wyze Cam v4. Have a family member or other close friend who wants to view your Wyze Cam v4? Share it with them right from the Wyze app.
Important: Only share your Wyze devices with people you know and trust.
To share your Wyze Cam v4:
  1. In the Wyze app, tap on your camera.
  2. Tap on the Settings gear > Sharing.
  3. Tap on the +plus sign to share with a new user.
  4. Enter the email address of someone new to share with, then tap Search, then Share.
    • Or, tap on an email address from your Recent Shares. Then tap Share.
The shared user will receive a notification in the app to accept the Wyze Cam.
To stop sharing:
  1. Open the Wyze app, then tap Account > Sharing.
  2. Tap on the user you want to remove, then Cancel.
What can a shared user do?
Shared users will be able to:
  • View the Live Stream and Event Videos.
  • Record a Live Stream.
  • Turn on and off Notifications.
  • Create RulesSchedules and Automations.
  • Move Wyze Cam Pan devices.
  • Enable and disable Motion Tracking.
  • Use the SoundSpeak, and Take Photo tools.
  • Turn on and off the device.
  • Turn on and off Night Vision.
  • View the Device Info.
  • Remove the device from their Wyze app.
Shared users will not able to:
  • Share a device shared with them.
  • Rename a device shared with them.
  • Change the Detection Settings or Alarm Settings.
  • View microSD card footage.
 Keep in mind:
  • There is no limit to the number of users you can share your Wyze devices with.
  • There is no limit to the number of Wyze devices you can share.
  • The sharing feature is set per camera. To share multiple devices, you'll have to invite users to each manually.
Still need help?
