Using Rules with your Wyze Lamp Socket
To learn all about Rules, Shortcuts, Schedules, Device & Service Triggers, and Location Triggers, start with the article: Using Rules with the Wyze app.
How do Rules work with Wyze Lamp Socket?
Rules help automate your Wyze Lamp Socket, making it easier to protect and monitor your surroundings whenever you want.
There are 4 kinds of Rules that can be used with Wyze Lamp Socket.
  • Shortcuts run actions with a tap in the Wyze app.
  • Schedules control devices based on the time of day.
  • Device & Service Triggers connect multiple Wyze devices so one can trigger another. Having a Wyze Services subscription offers additional AI-based triggers.
  • Location Triggers control devices based on your location.
Below are some example scenarios where Rules may be useful in your everyday life.
Shortcut
Rule Name: “Lamp On”
Scenario: You’d like to instantly turn your light on.
To create your Shortcut:
  1. In the Wyze app, tap on the + plus sign in the top left corner, then tap Add Rule.
  2. Tap the + plus sign in the top right corner, then tap Shortcut.
  3. Name your Rule “Lamp On”.
  4. Tap Add Action and select your Wyze Lamp Socket.
  5. Check the box next to Turn on. Tap Save.
  6. Tap Save again, and then you’re all set!
Schedule
Rule Name: “Night Light”
Scenario: When it becomes dark outside on the weekend, you want your Wyze Lamp Socket to turn on and then turn off when it is bright again.
To create your Schedule:
  2. Tap the + plus sign in the top right corner, then tap Schedule.
  3. Name your Rule “Night Light”, then tap Save.
  4. Select a Start Time of 8 pm and an End Time of 6 am.
    1. If you don’t set an end time, your lamp socket will stay on all day!
  5. Select the days you want this Rule to be active.
    1. For the weekend, simply select Saturday and Sunday.
  6. Tap Add Action, then choose your Wyze Lamp Socket.
  7. Check the box next to Turn on, then tap Save.
  8. Tap Save again, and then you’re all set!
Rule Name: “Who’s there?”
Scenario: When your Wyze Battery Cam Pro detects a Person, your Wyze Lamp Socket will turn on.
To create your Device & Service Trigger:
  2. Tap the + plus sign in the top right corner, then tap Device & Service Trigger.
  3. Name your Rule “Who’s there?”, then tap Save.
  4. Tap Device & Service Trigger, then choose your Wyze Battery Cam Pro.
  5. Tap on Detects a person, then tap Save.
    1. If you don't have Cam Plus, you can still use this Rule for when the camera detects motion, you'll just want to tap Detects motion. However, we recommend using Cam Plus for additional smart detections like vehicle, package, and pet detection. You can learn more about Cam Plus here.
    2. To sign up for Cam Plus, simply tap one of the Cam Plus options (Detects a person, Detects vehicle, Detects package, Detects a pet) and then tap Start My Free Trial to get started.
  8. If you'd like to have this Rule only trigger during a certain time or on specific days, toggle Time on then select your start and end times and the days of the week you'd like this Rule to be active.
  9. Tap Save.
  10. You’re all set!
Location Trigger
Rule Name: “Coming Home”
Scenario: You would like your Wyze Lamp Socket by your garage to turn on when you pull into your driveway.
To create your Location Trigger:
  2. Tap the + plus sign in the top right corner, then tap Location Trigger.
  3. Name your Rule “Coming Home”, then tap Save.
  4. Under IF, Select I arrive.
  5. Under The Location, tap your home address, then adjust the location radius.
    1. You can move the map with your finger, use two fingers and move them together/apart to zoom out/in, or use the arrows at the edge of the shaded circle to make the location radius smaller or larger.
    2. If your Location Permissions aren’t already enabled, you’ll receive an in-app prompt to enable this. You can enable Location Permissions by going to your phone’s settings.
  6. Tap Save.
  7. Tap Add Action, then tap your Wyze Lamp Socket.
  8. Check the box next to Turn on, then tap Save.
  9. If you'd like to have this Rule only trigger during a certain time or on specific days, toggle Time on then select your start and end times and the days of the week you'd like this Rule to be active.
  10. Tap Save, and then you’re all set!
Was this article helpful?
0 out of 0 found this helpful
  • Live Support Hours:
