Check out the video below to learn how to use your Birdie Personal Safety Alarm.
To use your Birdie alarm:
- Aim the speaker toward your target.
- Pull the removable pin from the body of the Birdie. The alarm will sound and the light will flash.
- To stop the alarm, reinsert the pin.
Note: The alarm will sound for ~40 continual minutes, or until you manually reinsert the pin.
