Problem
Wyze Scale Ultra is showing incorrect body composition measurements.
Note: Body composition metrics (body fat %, water %, etc.) are only available for people between the ages of 10-100 years old. Children under 10 and seniors over 100 will not be able to access the body composition features. For users between ages 10-17, the body composition metrics are only for reference.
Troubleshooting
- Confirm that your Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store, and update the Wyze app.
- If possible, check that your Wyze Scale Ultra’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the scale, please move forward with updating it.
- Ensure you are measuring correctly.
- Place the scale on a hard, flat surface.
- Step on the scale barefoot, without your knees touching.
- Make sure your feet are not too dry or damp as this may result in incorrect or no measurements.
- Remain on the scale until the measurement is complete.
- Wipe the surface of the scale with a damp cloth, then try measuring again.
- Verify the scale is syncing with the Wyze app.
- Open the Wyze app and select Wyze Scale Ultra.
- Step on the scale to activate it.
- Ensure Connected displays in the app and the BluetoothⓇ symbol appears in the upper-left corner of the scale’s screen.
- Ensure the correct user profile is selected in the Wyze app while measuring.
- Verify your personal information (i.e. body type, year of birth, etc.) is correct in the Wyze app.
- In the Wyze app, go to Wyze Scale Ultra’s settings > Users.
- Ensure that Pregnancy/Weight-Only Mode is not enabled in the Wyze app.
- Power cycle Wyze Scale Ultra.
- Remove the batteries for 10 seconds, then reinstall them.
- Factory reset Wyze Scale Ultra.
- On the back of the scale, in the battery compartment, find the UNIT button.
- Press and hold the button for 3 seconds until the scale display shows “Clear”.
- Set up the scale as new.
