View a Live Stream
You can view a live video stream of your Wyze Cam directly from the Wyze app whenever you’re connected to the internet.
To view the Live Stream:
In the Wyze app, tap on your Wyze Cam v1/v2 or Pan. Once it loads, you're viewing the Live Stream.
Live Stream Features:
Security: All Live Streams are encrypted via AES 128-bit encryption, symmetric and asymmetric encryption, and consistent hashing to ensure your Live Streams security.
Streaming Quality: View your Live Stream in HD, SD, or 360p quality with just a tap.
Having connection issues? Set your quality to SD or 360p to use less bandwidth.
Night Vision: Wyze Cam devices have an infrared light filter and infrared LED lights for viewing the live stream at night.
Sound: Listen to the camera’s microphone by tapping Sound on the Live Stream screen.
Record: Record a video of the stream directly from the Live Stream screen. Tap Record to start recording and Stop to finish recording.
Recorded videos are saved to your device’s photo gallery and can be viewed, sent, or shared from there or through the Album in the Wyze app.
Take Photos: Take a picture of the stream from the Live Stream screen. Tap Take Photo to take a picture. Photos are saved to the Album in the Wyze app.
Photos are saved to your device’s photo gallery and can be viewed, sent, or shared from there or through the Album in the Wyze app.
Speak: Talk to your pets or communicate with someone with the Speak feature.Using this feature turn on the Sound feature so you can hear the response.
From the Live Stream screen:
  • On Wyze Cam: Press and hold Speak to send your voice to the Wyze Cam.
  • On Wyze Cam Pan: Tap Speak to send your voice to the Wyze Cam. When finished speaking, tap Hang Up.
8x Digital Zoom: Use the two-finger pinch motion for up to 8x digital zoom of your Live Stream.
