Wyze Cam Pan can follow motion automatically. Using the pan and tilt features, whenever motion is detected, the camera can move to track the motion until motion stops.
This feature is only available on Wyze Cam Pan. It is not available on Wyze Cam v1/v2/v3.
To turn on Motion Tracking:
- In the Wyze app, tap on your Wyze Cam Pan.
- Tap More, then Motion Tracking.
- When green, Motion Tracking is On.
- When black, Motion Tracking is Off.
To turn on Motion Tracking, enter the Live Stream view on your Wyze App, tap the More icon and then the Motion Tracking icon. The Motion Tracking icon will be colored when it is turned on and will be gray when Motion Tracking is turned off.
Additional Notes:
- When the camera detects motion it will move to follow the motion to keep it within the camera's field of view. Once out of view, the camera will return to its initial position.
- If multiple objects are moving at the same time, Wyze Cam Pan will follow the largest moving object in view.
- After 15 seconds of inactivity (no motion detected), Wyze Cam Pan will return to its initial position OR continue the Pan Scan if one was in progress.
- Motion Tracking can be turned on and off independently of Motion Detection and Motion Tagging.
