Keeping Your Camera Updated
Wyze continues to add new features, bug fixes, and updates to the Wyze app. To ensure you have the best experience and access to the latest feature set, you will want to make sure you are using the newest version of the camera firmware and Wyze app.
Updating the Wyze app
The best way to keep your Wyze app up to date is to set your Wyze app to update automatically. This is done through a setting on your phone or tablet. You can see what version of the app you are using in the Account tab of the Wyze App by tapping About.
Firmware Update
Firmware is the software that runs on the camera itself. It is important to keep your camera’s firmware up to date so that it can function properly and enable new features as they are released. You will be prompted to update your camera’s firmware when there is a new version available. You can also check what version of firmware your camera has installed, and if there is a new version available through the Wyze app.
To do this, go to Account > Firmware Update. Here you will be able to see if you have the newest version. You also have the option to Upgrade All if a new firmware version is available.
