Scenes
Scenes let you create presets for your Brightness and Color for your Wyze Bulb.
To create a Scene:
  1. Open the Wyze app
  2. Tap on the Bulb’s listing in either the Devices list on the Home tab, or from within the Bulb’s group
  3. Set the Brightness and Color sliders to your preference
  4. Tap the + button beneath the sliders to add a Scene
  5. Name your Scene and tap Save
Note - You can have up to 3 Scenes saved at a time.
You can edit a Scene in two ways. The first is to press and hold it’s listing on the Bulb’s device page until the Edit window pops up. For the second method:
  3. Tap the SettingsSettingsGear__1_.png icon in the top right
  4. Go to Scenes
  5. Select the Scene you want to edit
To delete a Scene:
  3. Tap the Settings SettingsGear__1_.pngicon in the top right
  4. Go to Scenes
  5. Tap Edit
  6. Tap the dnd_sign.jpg icon next to the Scene you want to delete
