Can I control Wyze Bulb without the Wyze app?
Yes, you can control Wyze Bulb a few ways:
With the light switch
You can turn Wyze Bulb on/off at the light switch, just like your regular bulbs.
Note: Wyze Bulb will return to the color temperature and brightness that it was in prior to being turned off with a light switch. If there is a total loss of power due to an outage or other reasons, Wyze Bulb will turn on regardless of the previous state.
Using voice commands
Control your bulb using voice commands through Alexa, Google Assistant or automation applets in IFTTT.
Still need help?
