How do I turn my Wyze Cam on and off?
To turn your Wyze Cam on and off:
In the Wyze app on the Home screen, tap the ON or OFF icon next to your Wyze Cam.
Additional Notes:
  • You can also turn your Wyze Cam off and on from the Live Stream. Tap the More (. . . ) icon, then Turn Off or Turn On.
  • Turning the camera off from the Wyze app will not take it offline. The Live Stream and Event videos (which work in the cloud) will be disabled completely when the camera is turned off.
  • While turned off in the Wyze app, if your Wyze Cam loses its network connection or power, it will reconnect in the "On" state when the network/power is restored.
  1.
