The Wyze app lets you adjust your Wyze Bulb's Brightness and Color temperature, from warm white (2700k) to daylight (6500k).
To change the Brightness and Color:
- In the Wyze app, tap on your Wyze Bulb.
- Two sliders will be available; one for Brightness, the other for Color. Changing either of these should be reflected by the bulb in near-real time
