How sensitive is the motion sensor?
The PIR Motion Sensor uses Passive Infrared Light sensors to detect radiant heat. This means that it should ignore objects, shadows, and insects. Please keep in mind that, unlike with Wyze Cams, there’s no way to adjust the sensitivity of the Motion Sensor.
Click here to learn more about placing your sensor in the Sense User Guide.
Still need help?
