No sound in recordings
If you are not hearing sound in your recordings, try making sure that Record Sound is turned on by following these steps:
  1. Enter the Live Stream for the camera in question.
  2. Tap on the Settings icon SettingsGear__1_.png in the top right corner and navigate to Advanced Settings.
  3. If the Record sound option is toggled onToggleOn__1_.png , tap to toggle off ToggleOff.png
  4. If the Record sound option is toggled off ToggleOff.png, toggle the switch onToggleOn__1_.pngand back off ToggleOff.png.
  5. If there is still no sound on the recordings, please perform a factory reset on the camera and re-setup the camera.
Was this article helpful?
30 out of 145 found this helpful
