How can I change microphone permissions?
For Android:
  1. Go to your phone's setting and find the Wyze app settings. This is usually under 'Apps' or 'Apps & Notifications' sections.
  2. Go into the 'Permissions' section of the settings.
  3. Confirm the 'Microphone' permission is enabled.
For iOS:
  1. Open your phone's settings, scroll down until you see the Wyze app and select it.
  2. Under 'Allow Wyze to access' confirm that the 'Microphone' setting is allowed.
Still need help?
