Make it look like your home when you're away with Vacation Mode. If you have lights plugged into your Wyze Plug, you can use this feature to turn them off and on at random intervals between 6am-9am and 6pm-11pm local time.
To turn on Vacation Mode:
- Open the Wyze app and tap Wyze Plug.
- Tap Vacation Mode.
- If prompted to confirm, tap Turn On.
- Tap Vacation Mode again to turn it off.
Keep in mind
- Vacation Mode will remain enabled until you turn it off.
- Each Wyze Plug is limited to being turned on for between 5 and 60 minutes.
- Each plug with Vacation Mode enabled will turn on at least once per hour.
- Vacation Mode is has to be enabled on each plug.
