These are some of the top issues that we are currently working on or have resolved.
Description | OS or Device | Requested Information | Workaround | Status |
Crackling sound when viewing Events |
Camera firmware | In-progress | ||
Recording to a microSD card may stop when power is restored after an outage |
Audio and video out of sync when viewing Playback from a micro SD card |
Wi-Fi signal strength showing as not supported |
Wyze Cam v2 | This does not impact Wyze Cam functionality | In-progress | |
Old order history not displaying in the app |
Cloud | Contact customer support if you need to check on an order. Support Request Form |
In-progress | |
Set shortcut action to mute/unmute notification and the Home tab bell icon doesn't change the status automatically |
iOS/Android | In-progress | ||
Missing notifications |
Cloud/Platform | In-progress | ||
Alexa and IFTTT service is unstable |
In-progress | |||
Sensor showing offline | Firmware |
Insert a microSD card into the camera with the Bridge to collect a firmware log |
Unplug then plug in the Bridge or reboot the camera with the Bridge | In-progress |
Resolved Bugs
OS or Firmware | Description | App/Firmware Version Resolved |
Firmware | Wyze Sprinkler Controller: Fixed a bug that could cause water to shut off unexpectedly while watering. | 1.0.8 |
iOS/Android | Wyze Plug Outdoor: Fixed an issue where new firmware couldn't be installed because existing versions displayed up to date. |
2.27 |
iOS | Rules: Fixed a bug that caused Shortcuts to disappear | 2.27 |
Android | Cam Plus: App crashes when purchasing the Cam Plus service | 2.27 |
Android | Wyze Home Monitoring: HMS profile is deleted when clicking "Back" on the Hub plugin > Add Devices Page | 2.27 |
iOS | Wyze Video Doorbell: Unable to speak with two-way audio in live stream page | 2.27 |
Android | Wyze Plug Outdoor: Unable to use schedules | 2.27 |
iOS | App: iOS app crashes at launch for iOS 12 devices | 2.27 |
Android | App: Android app crashes due to signal 11 (SIGSEGV), code 2 (SEGV_ACCERR) | 2.27 |
Android | App: Android app crashes due to java.lang.NullPointerException | 2.27 |
Android | App: Android app crashes when accessing V3 setting page | 2.27 |
Firmware | Wyze Video Doorbell: Can't connect to TUTK on 4.25.0.302 firmware | 2.27 |
Firmware | Wyze Cam v2: No sound notification after assigning cam plus | 2.27 |
Android | App: Fail when deleting event from the bottom of the event list | 2.27 |
iOS/Android |
2.27 |
iOS | Wyze Light Strip: Missing icon options when setting up device | 2.26 |
iOS | Wyze Sense Hub:Sense Hub firmware update showing "Unknown Duration" | 2.26 |
iOS | Wyze Cam v3: UI overlapped on playback page | 2.26 |
iOS | Wyze Sense Contact, Motion Sensor V2: Devices offline metadate fix | 2.26 |
iOS | App: Made UI adjustments to the home page for iOS 15 | 2.26 |
Android | Cameras: Android 11 'Location permission' system page is shown if 'Allow' is clicked in the Allow Location modal when adding new camera | 2.26 |
Firmware | Wyze Cam v3: Fixed a siren noise bug |
4.36.6.17 |
Firmware | Wyze Buds Pro:Fixed a bug that caused the right earbud to turn noise cancellation off |
0.6.6.0 |
Firmware | Wyze Headphones: Fixed a bug that prevented muting in Zoom meetings on Windows devices |
2.1.143 |
Firmware | Wyze Headphones: Fixed the LED light status when the battery depletes |
2.1.143 |
Firmware | Wyze Headphones: Fixed a bug that caused failure to power on in some cases |
2.1.143 |
iOS | v3: Fixed a bug that caused event thumbnails from showing properly | 2.25 |
iOS | App: Fixed a bug that caused crashes when viewing video in landscape mode | 2.25 |
iOS | App: Fixed a bug that prevented the iOS app from receiving notifications | 2.25 |
Android | App: Fixed a bug that caused long load times when opening the settings screen for any Wyze Cam v3 | 2.25 |
iOS | App: Fixed a bug where different events were shown when refreshing the event list | 2.25 |
iOS | v3: Fixed a bug that caused the livestream image to distort while zooming in or out | 2.25 |
iOS | App: Fixed a bug that showed the "Problem connecting to server, please try again" error if an incorrect password was entered at login | 2.25 |
Android | Watch 44/47:Fixed a bug that prevented app sorting settings from being saved | 2.25 |
Android | Scale: Fixed a crash when exporting Wyze Scale data | 2.25 |
Firmware | Sprinkler: Fixed a bug that prevented Device Triggers from working when setting Sprinkler as the trigger | 2.25 |
iOS | Plug Outdoor: Fixed a bug that kept Plug Outdoor offline after setting up | 2.25 |
Android | Bulb Color: Fixed a crash when sorting devices within Wyze Bulb Color groups | 2.25 |
iOS | Video Doorbell: Fixed a bug that prevented from Wyze Lock from binding | 2.25 |
Firmware | Pan v2: Fixed a bug where Pan v2 continually restarted itself | 2.25 |
iOS/Android | App:Fixed a bug that prevented users from creating rules for Wyze Cam v3 | 2.24 |
iOS/Android | App: Fixed a bug that prevented users from accessing the Cam Plus page from the Account tab | 2.24 |
Firmware | WCO/Base: Fixed a bug that prevented users from setting up the WCO Base Station (LED flashing blue) | 2.24 |
Android | App: Fixed missing Cam Plus AI settings | 2.24 |
Firmware | v2/Pan: Fixed a bug that prevented users from updating firmware (Alpha only) | 2.24 |
iOS/Android | AI:Fixed a bug where vehicle detection notifications were not shown | 2.24 |
iOS | Bulb:Fixed a bug that prevented execution of Wyze Bulb scenes created in older app versions | 2.24 |
iOS/Android | Bulb: Fixed a bug that prevented the Timer function from displaying | 2.24 |
Android | v3: Fixed a bug that caused users to lose control of the event playback slider after tapping pause | 2.24 |
Android | v3: Fixed a bug that prevented users from downloading Time Lapse videos | 2.24 |
Android | v3: Fixed a bug that caused the app to crash when accessing camera groups | 2.24 |
Android | Watch 44/47:Fixed a bug that caused the app to crash after opening the Watch device page | 2.24 |
All | App: Fixed rules that were still executing after being deleted | 2.23 |
All | v3: Fixed inconsistency in Pop-up Messages between v3 and v2/pan | 2.23 |
Android | All Cams: Fixed a bug that prevented downloading time lapse videos for Wyze Cams | 2.23 |
Android | HMS: Fixed a bug that prevented live streaming on the Wyze Home Monitoring Security Camera page | 2.23 |
iOS | HMS: Fixed a bug that prevented Wyze Sense Hub from pairing for Wyze Home Monitoring | 2.23 |
iOS | Cam Plus:Fixed a bug that displayed the 12s limit icon for Cam Plus users in Sound Events | 2.23 |
iOS/Android | Thermostat: Updated the Behavior settings parameters for Wyze Thermostat | 2.23 |
iOS | Video Doorbell: Fixed a bug that turned off motion detection | 2.23 |
iOS | Bulb Color: Fixed a bug that prevented Wyze Bulb Color sleep routines from working | 2.23 |
iOS | Wyze Watch 44mm: Fixed a bug that prevented the display for weekly/monthly calories from showing | 2.23 |
iOS | v2/Pan: Device is offline (error code 90) or connection failed is shown even if refreshing device list after Panv1_4.X.7.798(DTLS+Authkey) is new added to device list. | 2.22+ |
iOS | Cam Plus: Camera has Cam Plus but some events still show "12s" icon | 2.22+ |
iOS & Android | App: Notifications delayed for more than an hour (alpha users) | 2.22+ |
Android | v2/Pan:Android App indicates "Failed to Update Firmware", but the firmware update was actually successful | App 2.22 |
Android | v2/Pan: Speaker doesn't work | App 2.22 |
Android | v2/Pan: Connection failed when entering live stream for the first time | App 2.22 |
Android | WCO: App not responding when clicking "Time Lapse" | App 2.22 |
Android | v3 Spotlight: resolved several crash issues related to Spotlight | App 2.22 |
Android | Entry Sensor v2: Cannot add device | App 2.22 |
iOS | Bulb Color: app crashes after using "Back" button in Color Bulb Plugin page | App 2.22 |
Android | Plug Outdoor: app crashes after device pairing | App 2.22 |
Android | HMS: App crashes after pairing the Sense Hub | App 2.22 |
iOS | HMS: App crashes when opening Security Camera for the first time | App 2.22 |
Android | All Cameras: Fixed No Notification when App is running in the background | App 2.21 |
Firmware | WCO: WCO Firmware Update Failed | App 2.21 |
Android | V2/Pan: Fix No Audio in V2 and Pan Cam Playback recordings | App 2.21 |
IOS | All Cameras: Fixed Any Event Older than the Most Recent One will be Perpetually Loading and Never Play | App 2.21 |
IOS | All Cameras: Fixed an issue causing IOS Events Video Keep Being Loaded | App 2.21 |
Android | All Cameras: Fixed mismatch SD card recording settings in Advanced Settings | App 2.21 |
Android | Doorbell:Fixed a bug that prevented Event videos from playing for Wyze Video Doorbell | App 2.21 |
iOS | Watch 47mm: Unable to setup | App 2.21 |
iOS/Android | App: Fixed a bug that displayed the 12s limit icon for Cam Plus users | App 2.21 |
Android | HMS: Fixed a bug that prevented Wyze Video Doorbell Live Stream for Wyze Home Monitoring | App 2.21 |
Android | Thermostat: Fixed a bug that prevented Auto-Switch function from working | App 2.20 |
iOS | Watch 44mm: Kept disconnecting from the phone | App 2.20 |
iOS | HMS: Users could not see "Allow Critical Alerts" for Wyze app in iOS settings | App 2.20 |
Firmware | v2/Pan: Event Video Error 06 issue improvement | 4.x.7.470 |
Firmware | v2/Pan: Updated firmware source code libraries for improved stability and performance | 4.x.7.470 |
Firmware | v2/Pan: Changed the audio format for compatibility with more video players and browsers | 4.x.7.470 |
Firmware | v2/Pan: Reduced the push notification delay time | 4.x.7.470 |
Firmware | v2/Pan: Fixed playback loud noise if sound is already open in live stream | 4.x.7.470 |
Firmware | Watch 47mm: jumps back to previous page after timer expires and cannot turn off vibration | App 2.19 |
Android | Wyze Scale: App crashes when tapping Wyze Scale | App 2.19 |
iOS | HMS: Continued to prompt Wyze Home Monitoring firmware updates when fully updated | App 2.19 |
Android | Wyze Cam V3: Can't download timelapse recordings | App 2.19 |
Android | Wyze Cam v2 & Pan: Can't take photo from paused playback | App 2.19 |
Android | Wyze Cam V2 & Pan: No videos listed in Playback timeline bar | App 2.19 |
Firmware |
Wyze Cam v2 & Pan: Fixed excessive sound alarms triggered by noise | Resolved in firmware version 4.x.6.243 |
Android |
Wyze Cam v2 & Pan: No videos listed in Playback timeline bar | Resolved in app version 2.19 |
Android |
Wyze Cam v2 & Pan: Can't take photo from paused playback | Resolved in app version 2.19 |
Android |
Wyze Cam v3: Can't download timelapse recordings | Resolved in app version 2.19 |
iOS |
Wyze Home Monitoring: Update prompts continued to appear after firmware has already been updated | Resolved in app version 2.19 |
Android |
Wyze Scale: App crashes when opening Wyze Scale | Resolved in app version 2.19 |
Firmware |
Wyze Watch 47: Menu moves to previous page after timer ends, vibration can't be stopped | Resolved |
Android |
All Cameras: Fixed issue with wrong volume control is adjusted when adjusting volume in live streaming | Resolved in app version 2.18 |
iOS & Android |
Wyze Cam v2 & Pan: Reduced the chance of experiencing Error 06 | Resolved in firmware version 4.x.6.241 |
Android | Wyze App: Fixed the wrong event video playing when launched through a notification | Resolved in app version 2.18 |
iOS | Wyze Plug Outdoor: Fails to connect during setup | Resolved in app version 2.18 |
Android | Wyze Thermostat & Wyze Scale: Fixed the "Delete Device" button not removing these devices | Resolved in app version 2.18 |
Android | Wyze Sprinkler: Fixed an issue causing Sprinklers to not be discovered in setup | Resolved in app version 2.18 |
Firmware | Event Video started later than thumbnail for non-CamPlus Videos | |
Firmware | Increased two-way audio volume for Wyze Cam v2 and Pan | |
iOS/Android | Viewing cameras are in a group forces close the group | |
Wyze Cam Outdoor | An IP address conflict issue prevented pairing with some Wyze Cam Outdoor cameras | |
Wyze Cam Outdoor | The Wyze Cam Outdoor thumbnail did not update properly | |
Wyze Cam Outdoor | Some Wyze Cam Outdoor cameras couldn't read the microSD card | |
Wyze Cam Outdoor | Wyze Cam Outdoor showed false success when disabling Travel Mode | |
Android/iOS | Cam Plus did not refresh after device setup | |
iOS | iOS live stream froze when using the live stream for extended periods of time | |
Android | Android app crashed when viewing the Events page | |
Android | The Wyze app prevented audio from a Bluetooth headset and uses the call channel | |
Android | Video and audio randomly froze | |
Cloud | IFTTT service frequently disconnected from Wyze | |
Android | Events were successfully deleted but the Events page fails to update | |
Android | When using hardware decoder, the beginning of the live stream was dark for 1-2 seconds | |
Camera Firmware | Some Wyze Cams had difficulty reading the micro SD card | |
Camera Firmware | Google Home had unstable live streaming after connection | |
Cloud | CMC Events were not triggering IFTTT applets | |
Cloud | Tablets without SMS function could not download the Wyze app from Google Play | |
Cloud | Two-step verification setup failed in some conditions | |
Cloud |
Alexa command response for Wyze Cams was sometimes not stable |
Wyze Cam Pan |
Some Wyze Cam Pans did not detect motion |
Cloud/Firmware |
Google Assistant live stream did not function for some users |
iOS/Android |
CMC videos did not have audio after downloading through the Wyze app |
Cloud |
Some users repeatedly had to agree to the updated Privacy Policy |
Android |
App prompted for a firmware upgrade when moving from grouped bulbs to individual bulbs though they were already on latest firmware |
Android |
Some users could not input the verification code when creating a new Wyze account |
Android |
Dark video for 1-2 seconds when viewing the live stream with hardware decoder enabled |
Camera firmware |
Some Wyze Cams had trouble reading microSD cards. The eject feature addresses this problem. |
Camera firmware |
Google Assistant live stream was not stable (would disconnect unexpectedly) |
Cloud |
CMC motion events did not trigger IFTTT rules |
Cloud |
Cloud |
Two-factor authentication failed under some circumstances |
Android |
Some users could not input the verification code when creating a new account |
Android |
Wyze Bulb prompt to upgrade firmware when already on the most recent firmware version |
Cloud |
Some users received repeated requests to accept the updated privacy policy |
iOS/Android |
CMC Event videos missing audio after download through the Wyze app |
Cloud/Firmware |
Google Assistant live stream not functioning |
Wyze Cam Pan |
iOS |
iPad can't select Saturday when setting Rule triggers |
iOS/Android |
CMC video won't zoom in when double tapped. |
Cloud/App |
Missing push notifications for existing Event videos |
Android |
Live stream lagging while using Android 7 and older devices |
iOS/Android |
Notification video time and device time are not synced |
Firmware |
The camera stops recording after losing WiFi connection |
Cloud |
Deletion failed after trying to delete a device |
Android |
Sharing event video from email shows wrong time |
iOS/Android |
List of Shared Users missing in app |
iOS |
iOS 13 can't get SSID when adding a new product |
iOS/Android |
Rule history showing timeout |
Camera Firmware |
Feedback log was oversized | |
iOS |
App doesn't generate log |
iOS/Android |
Shared user didn't receive pop-up window |
Camera firmware |
Time lapse videos won't download onto the phone or tablet while on the same network. |
iOS |
iOS 13 compatibility |
iOS/Android |
App crash when entering shipping info in Shop. |
Android Camera |
Camera live stream not showing the time stamp with hardware decoder on. |
Issue with Start/End Time on the same day when setting up Schedule |
Android |
Android issue report missing log in the email |
