Using Rules with Wyze Plug
To learn all about Rules, Shortcuts, Schedules and Device Triggers, start with the article: Using Rules with the Wyze app.
How do Rules work with the Wyze Plug?
Rules help automate your Wyze Plug, making it easier to turn it on/off with a single tap in the app, have it turn on/off at a scheduled time, or when triggered by another device.
  • Shortcuts run actions with a tap in the Wyze app.
  • Schedules control devices based on the time of day.
  • Device Triggers connect multiple Wyze devices so one can trigger another.
An example Shortcut with the Wyze Plug
To create a shortcut turn off your Wyze Plug with a single tap from the Home screen:
  1. Tap Home, then the + plus sign on the top left.
  2. Tap Add Rule, then select Shortcut from the list.
  3. Tap the Wyze Plug you want to create a shortcut for.
  4. Add a name for the shortcut in the text box under the star icon.
    • Try "Turn off plug"
  5. Tap the + plus sign next to Action.
    1. Tap on your Wyze Plug from the list.
    2. Tap Turns Off, then Save.
  6. When finished, tap Save.
Your shortcut will display with a star icon at the top of the Home screen.
An example Schedule with the Wyze Plug
To create a schedule to turn on your Wyze Plug every Sunday at 12:00 PM.
  2. Tap Add Rule, then select Schedule from the list.
  3. Tap the Wyze Plug you want to create a schedule for.
  4. Select Turn On, then Next.
  5. Tap the + plus sign next to Name (Optional).
    1. Enter a name for the schedule. Try "Turn on plug Sundays"
    2. Tap Save.
  6. Tap Start Time.
    1. Select 12:00 PM, then Save.
  7. Under Every, uncheck every day except Sunday in the list.
  8. Tap Save.
An example of Device Trigger with Wyze Plug
To create a device trigger that turns off your Wyze Bulb when your Wyze Plug has been off for 3 hours.
  2. Tap Add Rule, then select Device Trigger from the list.
  3. Tap the + plus sign next to Name (Optional).
    1. Enter a name for the schedule. Try "Turn off bulb and plug"
    2. Tap Save.
  4. Tap Device Trigger.
    1. Select your Wyze Plug.
    2. Tap Has been off for.
    3. Select 3 hours, then tap Save.
    1. Select your Wyze Bulb.
    2. Tap Turn Off, then Save.
