Fix Wifi Issues with our Self-Service app
Diagnose and troubleshoot Wifi using our self service app, RouteThis Helps. To find out more about the app and fix problems problems with network connectivity, setup, and video quality, please click here.
First, ensure that the outlet or fixture that the Wyze Plug is plugged into isn't controlled by a switch (such as a light switch or power strip.) If so, make sure it is turned on.
Next, try and power-cycle the Plug by removing it from the outlet, waiting at least 5 seconds, and then plugging it back in.
If this is a one-off case, you can also try to setup the Plug again. Start by removing it from the Wyze app by selecting the Plug from the Home tab. Then press the Settings icon and choose Remove Device at the bottom of the page. After removing the Wyze Plug you can add the product again by following the Wyze Plug Setup Guide.
