Two-Way Audio
Both Wyze Cam and Wyze Cam Pan give you the ability to speak and listen to your camera from the Live Stream using Two-Way Audio.
To turn on Two-Way Audio for Wyze Cam v1/v2:
  1. In the Wyze app, tap on your Wyze Cam.
  2. Tap and hold the Speak icon (microphone Speak_2.jpg) when you want to speak.
  3. You can now speak through your Wyze Cam.
    • To stop speaking and restore audio from the camera, release the Speak icon.
To turn on Two-Way Audio for Wyze Cam Pan:
  1. In the Wyze app, tap on your Wyze Cam Pan.
  2. Tap the Speak icon (microphone Speak_2.jpg).
    • The icon will turn green, and you will see "Speaking" appear on the Live Stream.
  3. You can now speak and listen through your Wyze Cam Pan.
    • To turn off Two-Way Audio, tap the Speak icon again.
Additional Notes
  1. For Wyze Cam v2, Two-Way Audio is similar to a walkie talkie where only one side can speak at a time.
    • Audio through the app will be disabled while you're holding the Speak icon. Audio will be re-enabled when you release the Speak icon.
  2. You cannot change or control the volume of the speaker or microphone.
