When ordering Wyze Sense, you have three options. If you are getting started, you will want to get the Wyze Sense Starter Kit. You can always expand the number of sensors you have with the Sense Contact Sensor Kit and the Sense Single Motion Sensor. Read more below to learn about the different kits and sensors available.
Sense Starter Kit
The Wyze Sense Starter Kit includes 1 Sensor Bridge, 2 Contact Sensors, and 1 Motion Sensor. You’ll also need a Wyze Cam or Wyze Cam Pan to use the Wyze Bridge. Wyze Sense is compatible with Wyze Cam v1, v2, and Pan.
The Wyze Sense Contact Sensor Kit includes four contact sensors.
Note: You will need to have the Wyze Bridge that is included in the Wyze Sense Starter Kit to use the Contact Sensors.
This option will include one Motion Sensor.
Note: You will need to have the Wyze Bridge that is included in the Wyze Sense Starter Kit to use the Motion Sensor.
