To learn all about Rules, Shortcuts, Schedules and Device Triggers, start with the article: Using Rules with the Wyze app.
How do Rules work with the Wyze Sense?
Rules help automate your Wyze Sense devices, making it easier to turn off notifications with a single tap in the app or at a scheduled time, or upload a video to the cloud when the sensor opens.
- Shortcuts run actions with a tap in the Wyze app.
- Schedules control devices based on the time of day.
- Device Triggers connect multiple Wyze devices so one can trigger another.
An example Shortcut with Wyze Cam Outdoor
To create a shortcut to turn off notifications with a single tap from the Home screen.
- Tap Home, then the + plus sign on the top left.
- Tap Add Rule, then select Shortcut from the list.
- Add a name for the shortcut in the text box under the star icon.
- Try "Turn off notifications"
- Tap the + plus sign next to Action.
- Tap on your Wyze Cam Outdoor from the list.
- Tap Turn off notifications.
- Tap Save.
- When done, tap Save.
Your shortcut will display with a star icon at the top of the Home screen.
An example Schedule with Wyze Cam Outdoor
To create a schedule to turn off motion detection every day between 6:00 PM and 6:00 AM. This comes in handy when you don't want motion-triggered events when you're home.
- Tap Add Rule, then select Schedule from the list.
- Tap the Wyze Cam Outdoor you want to create a schedule for.
- Select Turn off motion detection, then Next.
- Tap the + plus sign next to Name (Optional).
- Enter a name for the schedule. Try "Turn off motion detection"
- Tap Save.
- Tap Start Time.
- Select 6:00 PM, then Save.
- Tap Add End Time.
- Select 6:00 AM, then Save.
An example Device Trigger with Wyze Cam Outdoor
To create a device trigger that uploads a video to the cloud from your Wyze Cam when the sensor opens.
- Tap Add Rule, then select Device Trigger from the list.
- Enter a name for the schedule. Try "Upload video when sensor opens"
- Tap Save.
- Tap Device Trigger.
- Select your Contact Sensor.
- Tap Opens, then Save.
- Select your Wyze Cam Outdoor.
- Tap Upload a short video to the cloud, then Save.
