Turn ON/OFF
Wyze Cam Outdoor has a physical on/off switch on the back under the weatherproof seal, right next to the charging port. Since the camera doesn't need to be plugged in to turn it on, this is a manual way to turn the camera on or off if needed.
ONmceclip2.png OFF
You can also turn the Wyze Cam Outdoor on/off from within the Live Stream:
  1. In the Wyze app, tap the camera on the Home screen to view its Live Stream.
  2. Tap the btn3.png More icon under the live stream window.
  3. Tap Turn on or Turn off to toggle the camera on or off.
