Notifications
Customize when and where you'll receive notifications from the Wyze app about your Wyze Cam Outdoor.
To turn on/off Notifications for each device:
You can turn on or off push notifications for each individual Wyze camera you own.
  1. In the Wyze app, tap Home, then on your Wyze Cam Outdoor.
  2. Tap the Settings SettingsGear__1_.png icon in the top right, then Notifications.
  3. Next to Send Notifications, tap the toggle ToggleOn.png.
If an individual device has Send Notifications turned off, you will not receive any notifications from it. Even if all notifications are turned on using the steps below, you will not receive notifications for any device you disabled notifications for.
Turning on/off All Notifications
Don't want to receive any notifications from the Wyze app at all?
  1. In the Wyze app, tap Account, then Notifications.
  2. Next to Send Notifications, tap the toggle ToggleOn.png.
Just want to mute Notifications?
In the Wyze app, tap Home, then the Notifications bell on the top right.
