All Wyze Cam devices let you talk and listen using the camera's microphone and speaker. Use the 2-Way Audio feature to send sound through your device to the camera using the Wyze app.
To use 2-Way Audio:
- In the Wyze app, tap Home, then Wyze Cam Outdoor.
- Tap Speak
- When "Speaking" appears on the screen, you're ready to talk and listen.
- To turn off 2-Way Audio, tap Speak again.
Can I change the volume?
No, it is not possible to control the volume of the audio produced or recorded by the Wyze Cam Outdoor.
