Wyze Plug not working with Alexa
If you have trouble controlling your Wyze Plug with Amazon Alexa, try these troubleshooting steps:
  • Check if your Wyze Plug is listed in the Wyze app.
  • Check if you have the Wyze Skill enabled on Amazon.
  • Set up the Wyze Skill again
1. Open the Amazon Alexa app.
2. Tap on the three lines in the upper left-hand corner
3. Tap on Skills & Games.
4. Tap on Your Skills.
5. Tap on Wyze and delete the Wyze device (trash can symbol in the upper left corner).
6. Once deleted, unlink and relink your Wyze App with the Alexa App to re-discover the device.
Still need help?
