Do you see "Waiting for Wyze" in the Amazon Alexa app? Use the steps below to troubleshoot.
- Check if you have a firmware update.
- From the Wyze app, go to Account > Firmware Upgrade.
If your Wyze device doesn't have Up to Date next to it, tap Upgrade All.
- Check if your Wyze app is up to date.
- On Android, go to the Google Play Store. Update the Wyze app if needed.
- On iOS, go to the Apple App Store. Update the Wyze app if needed.
- Check if your Amazon Alexa app is up to date.
- Disable, then re-enable the Wyze Skill in the Amazon Alexa App.
- On the top left, tap Menu > Skills & Games > Your Skills > Wyze > Disable Skill > Disable.
- Return to the Wyze Skill and tap Enable to Use. Sign into Wyze and tap Accept.
- Follow the steps to Discover Your Devices.
