What is Secure Code Entry?
Wyze Lock Keypad has a unique feature called Secure Code Entry (also known as Anti-Peep). This lets you enter up to 20 numbers in any combination on either side of your code to help make sure nobody looking over your shoulder can know what the actual code is. As long as your code is entered correctly at some point in those 20 numbers, you're good to go!
Example: If your code is 0593, you can enter 13829405931945227396 and the door will still unlock.
