How do I remove the Wyze Band from my account?
To remove the Wyze Band in the app:
  1. Open the Wyze app and tap Wyze Band.
  2. Tap on the three dots (. . .) to open More.
  3. Tap Remove device.
To remove the Wyze Band from the band itself:
Tap on the Wyze Band screen, and scroll and tap the Setting screen. Scroll and tap Reset. The next time you launch the Wyze app, it will sync and your Wyze Band will be deleted from your account.
If you are on iOS, you will be redirected to System settings page to unpair the Bluetooth connection with “WYZE_Band”.
Still need help?
