How do I change the clock face on my Wyze Band?
To change the clock face:
  1. Open the Wyze app and tap Wyze Band.
  2. Tap on the clock icon.
  3. Choose one of the default clock faces and color schemes, or create your own.
    1. To use your own photo as the background, click More, then the add + button to choose from your device's photo album. When prompted, grant permission for Wyze to access the album.
    2. Select your photo, and crop the section you want to display on your Wyze Band.
  4. Tap Save to save your changes.
How to change from standard time to military time:
To change your time format for Wyze Band, you must change it on your mobile device. In your mobile device settings, go to Date & Time and switch to the 24-hour format. Save your settings if prompted, then return to the app.
Reload the Wyze Band page from the Home screen of the app to sync with your new settings.
Still need help?
