Is the Wyze Band waterproof?
No, your Wyze Band is water-resistant.
Wyze Band is 5ATM rated, which means it is tested to be water-resistant up to 164ft (50 meters) underwater for 10 minutes. Products with 5ATM rates are good for rainy weather, water splashes, swimming in shallow water.
Wyze Band is not recommended for intensive water sports or diving.
Can I swim or shower with my Wyze Band?
Yes, as long as you're not scuba diving in the tub. Wyze Band is rated to resist splashes (like while bathing) and shallow water.
If your Wyze Band comes in contact with anything other than fresh water, like chlorine or sea water, it should be cleaned with fresh water and dried with a lint free cloth.
When should I take my Wyze Band off?
Remove your Wyze Band before entering the sauna or steam room, before scuba diving or water skiing, and doing any other activity involving high velocity water or deep submersion.
Important: Do not expose your Wyze Band to soaps, shampoos, conditioners, lotions and perfumes as they can negatively affect water seals and acoustic membranes. Wyze Band's water resistance may diminish over time, and it cannot be rechecked or resealed for water resistance.
Still need help?
